Catalyst 6000 Supervisor Engine 2 ROMMON Upgrade
Mar 20th, 2007
I am unable to upgrade the ROMMON to release 7.1(1).
When I entered the upgrade rom-monitor command, instead of running the upgrade process it just copying the .srec file from tftp server.
Please kindly advice.
Amit Singh Tue, 03/20/2007 - 22:31
  • Cisco Employee,
Hello Friend,
As per the output attached you are on RP. Try the following and paste the output:
Router# remote command switch show version
The above should work and give you the output from SP.If you face any issues, try
Router# remote login switch
and then do the show version.
Check the boot rom strap version there.
HTH,
-amit singh
Amit Singh Tue, 03/20/2007 - 22:32
  • Cisco Employee,
Also, did you try reloading or resetting the sup engine after rommon upgrade?
-amit singh
