Cisco Juniper MPLS Integration Problem.
I had problem to integrate the Cisco router to the Juniper MPLS core network.
Cisco router is PE and Juniper M20 is P/PE router. The LDP is running fine between both routers, but the only problem faced is Cisco PE router do not receive "tag/label" from the Juniper router. Please refer to below capture.
Any advice what to check/verify when connecting Cisco and Juniper together in MPLS network.
16 Untagged 211.24.210.28/30 0 Gi0/1 211.24.210.169
17 Untagged 211.24.210.72/30 0 Gi0/1 211.24.210.169
18 Untagged 211.24.210.180/30 0 Gi0/1 211.24.210.169
19 Untagged 211.24.210.32/30 0 Gi0/1 211.24.210.169
20 Untagged 211.24.210.176/30 0 Gi0/1 211.24.210.169
21 Untagged 211.24.210.16/30 0 Gi0/1 211.24.210.169
22 Untagged 211.24.210.128/30 0 Gi0/1 211.24.210.169
23 Untagged 211.24.210.40/30 0 Gi0/1 211.24.210.169
24 Untagged 203.121.20.0/27 0 Gi0/1 211.24.210.169
25 Untagged 211.24.210.56/30 0 Gi0/1 211.24.210.169
26 Untagged 211.24.210.48/30 0 Gi0/1 211.24.210.169
27 Untagged 211.24.210.80/30 0 Gi0/1 211.24.210.169
28 Untagged 211.24.210.152/30 0 Gi0/1 211.24.210.169
29 Untagged 211.24.210.136/30 0 Gi0/1 211.24.210.169
30 Untagged 211.24.210.112/30 0 Gi0/1 211.24.210.169
31 Untagged 211.24.210.120/30 0 Gi0/1 211.24.210.169
32 Untagged 211.24.210.88/30 0 Gi0/1 211.24.210.169
33 Untagged 211.24.210.144/30 0 Gi0/1 211.24.210.169
34 Untagged 211.24.210.96/30 0 Gi0/1 211.24.210.169
35 Untagged 211.24.210.104/30 0 Gi0/1 211.24.210.169
36 Untagged 211.24.210.160/30 0 Gi0/1 211.24.210.169
glsfb4-mbone#sh mpls ldp bind
glsfb4-mbone#sh mpls ldp bindings
tib entry: 0.0.0.0/0, rev 740
local binding: tag: imp-null
tib entry: 10.10.11.0/25, rev 742
local binding: tag: 383
tib entry: 10.10.11.128/25, rev 172
local binding: tag: 99
tib entry: 10.10.12.0/25, rev 744
local binding: tag: 384
tib entry: 10.10.12.128/25, rev 746
local binding: tag: 385
tib entry: 10.10.13.0/25, rev 748
local binding: tag: 386
tib entry: 10.10.13.128/25, rev 750
local binding: tag: 387
tib entry: 10.100.1.0/24, rev 174
local binding: tag: 100
tib entry: 10.250.254.0/27, rev 752
local binding: tag: 388
tib entry: 10.250.254.1/32, rev 176
local binding: tag: 101
tib entry: 10.250.254.2/32, rev 178
local binding: tag: 102
tib entry: 10.250.254.3/32, rev 180
glsfb4-mbone#sh mpls ldp discovery all
Local LDP Identifier:
10.254.250.14:0
Discovery Sources:
Interfaces:
GigabitEthernet0/1 (ldp): xmit/recv
LDP Id: 10.254.250.17:0
glsfb4-mbone#sh mpls ldp neighbor
Peer LDP Ident: 10.254.250.17:0; Local LDP Ident 10.254.250.14:0
TCP connection: 10.254.250.17.2353 - 10.254.250.14.646
State: Oper; Msgs sent/rcvd: 843/370; Downstream
Up time: 01:00:53
LDP discovery sources:
GigabitEthernet0/1, Src IP addr: 211.24.210.169
Addresses bound to peer LDP Ident:
211.24.210.169
Harold Ritter Wed, 03/21/2007 - 06:59
  • Cisco Employee,
It appears thet the M20 is not sending any label in our direction. Are you by any chance filtering labels on the M20.
Hope this helps,
mheusinger Wed, 03/21/2007 - 07:48
  • Green, 3000 points or more
check, if there is an outbount LDP filter in the Juniper router:
LDP { export }
This could explain the described behaviour.
Regards, Martin
jiangu Thu, 03/22/2007 - 23:56
By default, JUNOS LDP only advertises /32 loopback prefix-FEC bindings upstream, you need to explicitly configure egress policy under LDP to advertise other prefix-FEC mappings.
Side qeustion, why do we need the label mapping for other prefixes except loopbacks anyway? what application will need that?
Harold Ritter Fri, 03/23/2007 - 07:30
  • Cisco Employee,
Jian,
I agree with you that advertising labels for loopback interface addresses is preferable in most cases. You can use "tag-switching advertise-tags" command on the IOS side to only allow loopback interface addresses to propagate.
Hope this helps,
Hi all, sorry for late reply.
Basically the VPN routes is sucessful advertised. The only problem is the next-hop ip (loopback) learn is not tag.
I can extended ping from 172.16.1.10 to 172.16.1.15 , but I cannot ping from 172.16.1.10 to 172.16.1 as the next hop is 10.254.250.16, which is not tag/label.
10.254.250.17 is LDP neighbor router loopback which is " POP-Tag".
glsfb4-mbone#sh ip ro vrf TEST
Routing Table: TEST
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
172.16.0.0/32 is subnetted, 3 subnets
C 172.16.1.10 is directly connected, Loopback9930
B 172.16.1.5 [200/0] via 10.254.250.17, 01:04:16
B 172.16.1.1 [200/0] via 10.254.250.16, 01:04:16
37 Untagged 10.254.250.1/32 0 Gi0/1 211.24.210.169
38 Untagged 10.254.250.2/32 0 Gi0/1 211.24.210.169
39 Untagged 10.254.250.3/32 0 Gi0/1 211.24.210.169
40 Untagged 10.254.250.4/32 0 Gi0/1 211.24.210.169
41 Untagged 10.254.250.5/32 0 Gi0/1 211.24.210.169
42 Untagged 10.254.250.6/32 0 Gi0/1 211.24.210.169
43 Untagged 10.254.250.7/32 0 Gi0/1 211.24.210.169
44 Untagged 10.254.250.8/32 0 Gi0/1 211.24.210.169
45 Untagged 10.254.250.9/32 0 Gi0/1 211.24.210.169
46 Untagged 10.254.250.10/32 0 Gi0/1 211.24.210.169
47 Untagged 10.254.250.11/32 0 Gi0/1 211.24.210.169
48 Untagged 10.254.250.12/32 0 Gi0/1 211.24.210.169
49 Untagged 10.254.250.13/32 0 Gi0/1 211.24.210.169
50 Untagged 10.254.250.15/32 0 Gi0/1 211.24.210.169
51 Untagged 10.254.250.16/32 0 Gi0/1 211.24.210.169
52 Pop tag 10.254.250.17/32 0 Gi0/1 211.24.210.169
53 Untagged 10.254.250.254/32 0 Gi0/1 211.24.210.169
Harold Ritter Tue, 03/27/2007 - 05:59
  • Cisco Employee,
Did you make the change I recommended on glsfb3 to include all the interfaces under the LDP process as follow:
protocols ldp {
interface all;
JunOS will not announce a label for a given prefix (FEC) unless it has already received a label for that same prefix. So glbp3 basically needs to receive a label for 10.254.250.16/32 from GLM-1 before it can advertise it to glbp4.
Hope this helps,
Harold Ritter Tue, 03/27/2007 - 06:25
  • Cisco Employee,
Note that you do receive a "implicit null" label for 10.254.250.17/32 (glbp3), which confirms that LDP is working properly between glbp3 and glbp4.
I notice that you are not using LDP in the core but RSVP instead. You could tunnel LDP over your MPLS TE tunnels by adding the ldp-tunneling command under each label-switch-path stanza as follow:
protocols {
mpls {
label-switched-path xxx {
from source;
to destination;
ldp-tunneling;
Note that this will have to be done at both end.
Hope this helps,
Ali Norouzi Tue, 12/21/2010 - 04:33
jiangu I had same issue and by using your comment the problem resolved.
My desired application is MPLS forwarding. I want to forward all the traffic with MPLS lable.
Thank you,
Harold Ritter Fri, 03/23/2007 - 07:26
  • Cisco Employee,
Try "interface all" instead of "interface fe-0/1/0.0" under the "protocols ldp" stanza on the Juniper side.
This will most probably fix your issue.
Hope this helps,
