Sup 720 Boot
Answered Question
Mar 20th, 2007
Simple question (I hope)
Using 6500 with Sup 720. I have set the boot variable to an image on disk1. Can I have multiple boot variables in the config, if so, in what order are they processed? Can they refer to disk0 and disk1?
Ian
Correct Answer by Amit Singh about 9 years 11 months ago
As Mahmodd said, you can have multiple boot statements and they are executed in sequence starting from 1st to last i.e in the order they were entered.
The router stores and executes the boot system commands in the order in which you enter them in the configuration file. If you enter multiple boot commands of the same type (for example, if you enter two commands that instruct the router to boot from different network servers), the router tries them in the order in which they appear in the configuration file
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
Correct Answer
Amit Singh Tue, 03/20/2007 - 22:38
-amit singh
