No DHCP on wireless LAN
Mar 21st, 2007
Hi guys, I have a Cisco 857W wireless ADSL router and I can get my windows XP w/s to connect but no IP address is assigned. I get a message saying limited or no conenctivity.
Relevant config is:
interface Dot11Radio0
description Wireless LAN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
encryption vlan 1 key 1 size 128bit xxx transmit-key
encryption vlan 1 mode wep mandatory
ssid NOC
vlan 1
authentication open
guest-mode
infrastructure-ssid
world-mode dot11d country AU both
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
bridge-group 1
interface Vlan1
description Internal LAN
ip address 10.10.10.1 255.255.255.248
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1412
Any ideas?
Dean
prakashj Wed, 03/21/2007 - 10:14
Hi Dean,
You can try with following config
ssid NOC
channel 2452
station-role root
bridge-group 1
interface FastEthernet0.1
encapsulation dot1Q 1 Native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
ip dhcp pool LAN
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
I hope it will help you.
Thankx&Regds
Saji k.s
bporter78 Fri, 04/06/2007 - 09:35
ok you haven't setup your bridge-group 1 properly.
Your DHCP pool is associated with Vlan1 - however your dot11radio0 is associated with Bridge-group 1 and Vlan 1 isn't - therefore you won't get ip's assigned from your DHCP pool.
Do this and you will be sweet:
ip dhcp pool Local
import all
dns-server 10.10.10.1
bridge irb
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
no ip address
broadcast-key change 60
encryption mode ciphers tkip
ssid NOC
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 'enter your keye here'
station-role root
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip access-group Outbound in
ip nat inside
bridge 1 protocol ieee
bridge 1 route ip
