Cisco Client + Dial up problems
Mar 21st, 2007
I am experiencing a difficult issue with the Windows Cisco VPN Client (4.6.02)
The client connects fine over a cable broadband connection, but when connected over a dial up connection, the client generates a "Bad hash payload" type errorset.
Can anyone help with this? I have tried several hours of trouble shooting without any progress.
Thanks.
kaachary Wed, 03/21/2007 - 05:53
Can you please post the complete logs from the client.
-Kanishka
cailenfisher Wed, 03/21/2007 - 06:22
Cisco Systems VPN Client Version 4.6.02.0011
Copyright (C) 1998-2004 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.0.2195 Service Pack 4
Config file directory: C:\Program Files\SpheriX\SpheriX VPN\
1 16:18:38.171 03/20/07 Sev=Warning/3 IKE/0xE3000056
The received HASH payload cannot be verified
2 16:18:38.171 03/20/07 Sev=Warning/2 IKE/0xE300007D
Hash verification failed... may be configured with invalid group password.
3 16:18:38.171 03/20/07 Sev=Warning/2 IKE/0xE3000099
Failed to authenticate peer (Navigator:904)
4 16:18:38.171 03/20/07 Sev=Warning/2 IKE/0xE30000A5
Unexpected SW error occurred while processing Aggressive Mode negotiator:(Navigator:2202)
5 16:21:14.828 03/20/07 Sev=Warning/3 IKE/0xE3000056
6 16:21:14.828 03/20/07 Sev=Warning/2 IKE/0xE300007D
7 16:21:14.828 03/20/07 Sev=Warning/2 IKE/0xE3000099
8 16:21:14.828 03/20/07 Sev=Warning/2 IKE/0xE30000A5
kaachary Wed, 03/21/2007 - 06:40
Are you sure , you are using the same group when connecting through dialup ?
It says, the group password is incorrect, please make sure, the group name and password is the same.
-Kanishka
cailenfisher Wed, 03/21/2007 - 06:46
The exact same configuration connects without fail over the cable broadband connection. Same group name, password, etc.
The errors only occur when connecting of dial up. I have checked and made sure hardware compression is off on the modem, software compression is off, etc.
