OID's required
Mar 21st, 2007
I need to get OID for the following items for Cisco 7206 Routers, 6500,4500,4000 Series Switches and 515 E Firewall for the following features:
1. Power Unit Status
2. CPU Utilization (One Minute/ five minute average)
3. Memory
4. Temperature
5. Interface Status
Where to get these ?
Pete
Overall Rating: 4.7 (5 ratings)
David Stanford Wed, 03/21/2007 - 06:45
Have a look at these MIB's specifically:
1. Power Unit Status - CISCO-STACK-MIB, CISCO-ENVMON-MIB, ENTITY-MIB and ENTITY-FRU-CTRL-MIB ex) ciscoEnvMonVoltageStatusTable
for IOS and chassisPs1Status for CatOS
2. CPU Utilization (One Minute/ five minute average) - CISCO-PROCESS-MIB ex) cpmCPUTotal5sec
3. Memory - CISCO-MEMORY-POOL-MIB ex) ciscoMemoryPoolTable
4. Temperature - CISCO-ENVMON-MIB and CISCO-STACK-MIB
5. Interface Status - IF-MIB and CISCO-STACK-MIB
Once you find the objects you want you can translate from name to number at:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
Craig Balfour Wed, 03/21/2007 - 08:09
All of the Cisco MIBS are available in ftp://ftp.cisco.com/pub/mibs/v2/v2.tar.gz.
Open the MIBs in a text editor and read through some of the descriptions - they are actually quite useful for determining what the MIB does and how to use it.
1. For power supply status take a look at the CISCO-ENVMON-MIB MIB. Querying
ciscoEnvMonSupplyState.1 (.1.3.6.1.4.1.9.9.13.1.5.1.3.1), for example will give you that status (normal, etc) of power supply 1.
2. For CPU status look at CISCO-PROCESS-MIB. For example querying cpmCPUTotal1minRev.1
(.1.3.6.1.4.1.9.9.109.1.1.1.1.7.1) returns the overall CPU busy percentage in the last one minute on the first CPU. Similarly, querying cpmCPUTotal5minRev.1 gives you the same data for a five minute period.
3. Various bits of memory related information is also available via CISCO-PROCESS-MIB.
4. Temperature information is available in the CISCO-ENVMON-MIB MIB.
5. Basic interface status information is available via RFC1213-MIB. Look at the ifTable object for a table of information.
Many MIBs define Table objects which provide lots of useful data in a tabular form. For example querying ifTable in RFC1213-MIB returns as table of interfaces with information such as a interface description, speed, physical address, admin status, operational status, in and out octets etc.
The most useful way I have found to query a MIB table object is using the Net-SNMP [1] snmptable utility as follows (on a unix machine):
snmptable -M /usr/share/snmp/mibs -m ALL -v 1 -c public 192.168.100.1 ifTable | less -S
1. http://net-snmp.sourceforge.net
