ping works. but ping with timestamps doesn't. any ideas?
m.matteson
Level 2
Level 2
I wanted to generate an excel chart of the time it takes to ping from one site to another site across my ipsec vpn. I was hoping to use the timestamp option with ping to get the time and then graph that in
reference to the ms delay in the relay. i would redirect the STDOUT to a txt file. here is my issue. using the timestamp option is works on anywhere in this building if it is local, but the pings timeout when they go across the vpn when the timestamp option is enabled. regular pings work. i included a JPG of what i'm talking about.
fmeetz
Level 4
Level 4
enabling time stamps does not create a problem. You may have given other otions incorrect while you gave the extended ping
