501 site-to-site vpn tunnel timeout
b_ferguson
Does anyone know what the maximum timeout a site-to-site vpn tunnel can have? 24 hours? I have tried to find some documentation as well but with no luck, if you have a link to this info, could you post that as well. Thanks for all your help...
8 Replies 8
ggilbert
Can you please let me know what kind of a device you are asking about?
On a Concentrator and ASA you can do that.
Its normally set to "zero" which means "None" -
For a site to site tunnels, it will be lifetime of Phase 1 and Phase 2 that will come into play for negotiation.
Rate this post, if it helps.
Gilbert
2 pix 501s
On a PIX 501, you can set the ipsec lifetime but not the Max-connect time for a tunnel.
Here is the command to set the security association lifetime.
crypto ipsec security-association lifetime seconds
Cheers
Gilbert
I am aware of how to set the lifetime, I am just trying to find out what the maximum lifetime the tunnel will stay connected if no traffic is on the tunnel.
Thanks for your responses...
If there is no interesting traffic passing through and when the time comes for re-negotiation due to lifetime expiry, then the SA will not be negotiation since the interesting traffic will not pass through.
So, to answer your original question, on a PIX 501, there is no "Max-connect time" setting for a site to site tunnel.
Gilbert
So what about the re-negotiation lifetime? Does it have a maximum limit that you set the lifetime of the tunnel. I have been told that the limit is 24 hours.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/gl.htm#wp1027585
Default isakmp lifetime is 86400 - Phase 1
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/c.htm#wp1026972
Default ipsec lifetime is 28800 - Phase 2
Phase 1 - 86400 is the Maximum. You can specify 0 seconds for infinite lifetime. (Which might be a security problem - possible Man in the Middle attack scenario)
Phase 2 - I would leave it to the default to set it to something less than or equal to phase 1.
Hope this helps.
Gilbert
Thanks, Gilbert, that is what I was looking for!
