VPN Connection issues
Mar 21st, 2007
I can initialize a VPN session on my PIX just fine however it comes up with the following box..
"The server has requested the following information to complete the user authentication: Then username password"
Where is this username/password coming from? The group information possibly?
This is a pix 506e that the company moved from another branch offce. I don't have any Taccacs or Radius information should I get rid of that? Where is it trying to authenticate from?
Overall Rating: 5 (1 ratings)
ggilbert Wed, 03/21/2007 - 10:01
Lance,
If you have a command on your PIX - something like
crypto map mymap client authentication
Then take that out.
You will not be prompted for user authentication.
Hope this helps. Rate this post!
Gilbert
ixholla69 Wed, 03/21/2007 - 10:09
I have -
crypto map outside_map client authentication RADIUS
That it? I was thinking this may be it but not 100%
ggilbert Wed, 03/21/2007 - 10:23
Remove that and it should not ask for user authentication.
Rate this post, if it helped.
Gilbert
ixholla69 Wed, 03/21/2007 - 18:31
Well I tried to remove this line but it just wont budge lol
aaa-server RADIUS (inside) host exchange.srvfarm.xxxxxxx.com !2N0w%f3fhrP time5
Kinda wondering if I should be checking something on the Radius server or maybe I'm not putting the right information in the login tab :/
ggilbert Thu, 03/22/2007 - 05:27
Remove this line.
Dont worry about the aaa-server on there.
See if the client can connect without the user authentication prompt.
Gilbert
