Connect dialup modem to Sup720
Answered Question
Mar 21st, 2007
Is there a way to connect a dialup modem directly to Sup720 for dialin connection without using the terminal router?
M--
Correct Answer by ankbhasi about 10 years 3 months ago
Hi M,
See if this link helps you, it worked for with sup 2 so I believe it should work for sup 720 also
http://www.cisco.com/warp/customer/471/50.html#miscellaneous
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
nguyen.minh Thu, 03/22/2007 - 08:29
Yes Ankur, this have solved my problem. Really appreciated for your helps.
Thank you,
M--
