pgcristovam Thu, 03/22/2007 - 04:21
Hi Frank.
But i think that CNA not support upgrade IOS without stop the operation switch. Or support? I don't know if exists it!
Peterson
Craig Balfour Thu, 03/22/2007 - 04:26
It is not possible to upgrade the IOS on a Catalyst 2950 without restarting the switch.
You can install the new IOS image on the switch without a reboot but you will need to restart the switch for it to load the new IOS image and to start using it.
frankzehrer Thu, 03/22/2007 - 04:57
you *must* reboot the devices after IOS Upgrade. There is no choice.
Best regards,
Frank
pgcristovam Thu, 03/22/2007 - 05:33
Yes!
My customers wanted it and i don't knowed this solution. So, my opinion is correct!
