WISM Error : Keepalive messeges are lost .....
Mar 21st, 2007
Anyone seen this error on a WISM modul befor,
----------------snip----------------
Message
Keepalive messages are lost between Master and Controller'172.31.228.8'.
Help
Keepalive messages are lost between Controller '172.31.228.8'and Master.Please check the controllers port configuration, any software or hardware incompatibility issues.
172.31.228.8 > Controller Properties
Misconfigured WiSM Controller #0
WISM modul are placed in to 6509, directly connected,
Best Regards
Peter
ankbhasi Wed, 03/21/2007 - 23:02
  • Cisco Employee,
Hi Peter,
Can you paste the output of "sh run | in wism" from your supervisor?
Ankur
p.danielsen Wed, 03/21/2007 - 23:45
Hi Ankur,
sh run | in wism
wism service-vlan 9
shows the same on both routers,
Peter
john.preves Mon, 05/14/2007 - 07:51
  • Silver, 250 points or more
Was there ever a resolution for this issue?
ericgarnel Thu, 12/11/2008 - 11:04
  • Gold, 750 points or more
Check your etherchannel load-balancing config
It should be:
sh etherchannel load-balance
EtherChannel Load-Balancing Configuration:
src-dst-ip
to configure it:
show6506A(config)#port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
dst-mixed-ip-port Dst IP Addr and TCP/UDP Port
dst-port Dst TCP/UDP Port
mpls Load Balancing for MPLS packets
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-dst-mixed-ip-port Src XOR Dst IP Addr and TCP/UDP Port
src-dst-port Src XOR Dst TCP/UDP Port
src-ip Src IP Addr
src-mac Src Mac Addr
src-mixed-ip-port Src IP Addr and TCP/UDP Port
src-port Src TCP/UDP Port
Jason Aarons Wed, 12/10/2008 - 11:33
  • Bronze, 100 points or more
Were you able to resolve this? What was the fix?
