authentication with rsa token failed
Mar 21st, 2007
hello everybody,
we installed a new wlc 4404 for wireless access.before we installed autonomus AP and with this all works fine!
the problem is with the client authentication.
old installation: Odyssey Client<>AP<>ACS<>RSA Server
new installation: Odyssey Client<>LWAP<>4404WLC<>ACS<>RSA Server
when i authenticate with the old installation: Peap starting with odyssey client , i enter response and i am open authenticated
when i authenticate with the new installation:Peap starting with odyssey client, i enter response i can not authenticate always the popup window for enter the response (passcode) comes up!
whats the problem?
its strange, when i autenticated with the old installation then i change to new installation i dosent must authenticate again and it works over the new installation. i recive a new ip from the WLC pool. when i start the pc new and i will authenticate with the new installation its doesent work.
thanks for a response
nik
ankbhasi Wed, 03/21/2007 - 23:46
  • Cisco Employee,
HI Nik,
I beleive in your new setup your controller can ping/reach ACS?
Ankur
n.steffen Thu, 03/22/2007 - 04:17
Hi Ankur,
Yes i can ping the ACS from WLC
ACS Software v 3.3
WLC Software 4.0.206.0
Nik
n.steffen Thu, 03/22/2007 - 11:24
Hello
new info from WLC authentication log:
Thu Mar 22 18:20:09 2007 [SECURITY] 1x_ptsm.c 407: MAX EAP retransmissions reached for mobile 00:18:de:a5:a4:ef
Thu Mar 22 18:20:06 2007 [SECURITY] 1x_bauth_sm.c 423: Backend Authentication SM: abortAuth: Authentication Aborted.
Thu Mar 22 18:19:59 2007 [SECURITY] 1x_ptsm.c 407: MAX EAP retransmissions reached for mobile 00:18:de:a5:a4:ef
Thu Mar 22 18:19:59 2007 Previous message occurred 2 times
Thu Mar 22 18:19:19 2007 [SECURITY] 1x_auth_pae.c 2448: Reached Max EAP-Identity Request retries (21) for STA 00:18:de:a5:a4:ef
Thu Mar 22 18:18:59 2007 [SECURITY] 1x_ptsm.c 407: MAX EAP retransmissions reached for mobile 00:18:de:a5:a4:ef
Thu Mar 22 18:18:59 2007 Previous message occurred 2 times
Thu Mar 22 18:18:51 2007 [SECURITY] aaa.c 661: Authentication succeeded for admin user 'admin'
Thu Mar 22 18:17:25 2007 [SECURITY] 1x_ptsm.c 407: MAX EAP retransmissions reached for mobile 00:18:de:a5:a4:ef
Thu Mar 22 18:16:45 2007 [SECURITY] 1x_auth_pae.c 2448: Reached Max EAP-Identity Request retries (21) for STA 00:18:de:a5:a4:ef
Thu Mar 22 18:16:32 2007 [SECURITY] aaa.c 661: Authentication succeeded for admin user 'admin'
Thu Mar 22 18:16:25 2007 [SECURITY] 1x_auth_pae.c 2448: Reached Max EAP-Identity Request retries (21) for STA 00:18:de:a5:a4:ef
n.steffen Tue, 03/27/2007 - 12:06
the problem is solved. we changed the timmer setting on wlc...
shinkang.seo Tue, 06/12/2007 - 21:38
Hi, I am also facing your problem which is little bit different. We can use Wireless for few hours however it did not last for a long time. Some user can use 2~3hours but suddenly request re-authentication. I would like to know what I can refer to solve this. Could you advise?
Our infrastructure is the same as you.
Trending Topics - Security & Network
