SMI and EMI
Hi.
The SMI version do routing inter-vlan?
Thanks.
5 Replies 5
matt_heff
feel free to read my post below yours about 3750 inter-vlan routing with SMI. i believe it is supported but i'm having a tough time getting it working!
matt
Yes the SMI does support interVLAN routing with only basic routing functionality being supported.
bosoro
Platform-dependent, you get Static routes, RIP, and EIGRP-Stub in the IP Base (formerly SMI) at no cost.
Net-result, you should have inter-vlan routing.
Dumb question: Did you type "ip routing" in global config?
-b
Hi.
3750 with SMI accept "ip routing".
Hi Friend,
Yes it will accept "ip routing" command and will do all basic routing like static rouing, intervlan routing and also support routing protocokl like RIP.
switch(config)#ip routing
Ankur
*Pls rate all helpfull post
