Personal Address Book - LDAP CCM 5.0.4
Mar 21st, 2007
I have the LDAP service running on Callmanager 5.0.4.,the Personal Address Book is request for the users, but i ?m trying to access http ccmuser, and the access is denied. Any idea?
regards
Cristian
thisisshanky Thu, 03/22/2007 - 12:37
  • Purple, 4500 points or more
Assign the user to the Standard CCM User group and you should be able to login.
Sankar
PS: please remember to rate posts!
cristian.munoz Tue, 03/27/2007 - 14:50
Dear Sankar
It?s working. I can access to web user. Thank you. But, now i have the follow problem:
- When i try access to Personal Address by IP Phone request to me User and PIN , but not support letters.
Is this PIN the LDAP password?s?
thisisshanky Tue, 03/27/2007 - 16:55
The pin should be the user pin that you configure under the user. This is a numeric (no alphabets)
Sankar
cristian.munoz Wed, 03/28/2007 - 06:27
Dear Sankar
you talk about into the End User Configuration Page? If yes, remember that this user id and pin are into the LDAP.
thisisshanky Wed, 03/28/2007 - 09:36
Yes the pin you configure under end user. Are you AD integrated ?
cristian.munoz Wed, 03/28/2007 - 16:25
Dear Sankar
I have LDAP integrated, and i not like modify this pin , because is the domain?s pin.
f.giordano Wed, 03/28/2007 - 13:08
I think I can help you...
Cisco had the good idea to create new feature in CCM 5 ==> Role and Group.
So the only think you need to do, is to go through the admin web page to the USER MANAGEMENT Tab, and then select "GROUP".
You'll see different group, and a specific one "Standard CCM user" or something like that.
Just click on it, and you can add now all your End-User to this group. And then all the user can access to the ccm user page with the USERNAME and PASSWORD field (not the pin).
Fabian
cristian.munoz Thu, 03/29/2007 - 06:43
Dear Fabian
I configured this feature. Th clients can access to ccmuser. My problem is that the clients can not access to personal directory by access key of IP Phone.It say: User and PIN. What PIN?LDAP PIN?
