Cisco 3845 Link Redundancy
cpembleton Mon, 03/26/2007 - 21:24
You could put each interface in a differnt subnet on the cores. Then you could configure floating static routes. Or you could use a dynamic routing protocol like OSPF or EIGRP. Or you could you Policy based routing to control the traffic route. Or you could use object tracking to insert the default route depending which one is up.
Really depends on what your running for your cores and what they support.
http://www.cisco.com/en/US/customer/tech/tk365/technologies_tech_note09186a00800ef7b2.shtml
http://www.cisco.com/en/US/customer/products/ps6599/products_white_paper09186a00800a4409.shtml
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html
http://www.cisco.com/en/US/customer/tech/tk365/tk480/tsd_technology_support_sub-protocol_home.html
Hope this gets you in the right direction.
Chad
Please rate if this helps!
