inter-vlan routing troubles drving me crazy!!!
Mar 21st, 2007
I'm reposting this because I inadvertantly marked my question as solved, but it isn't. I still can't get inter-vlan routing going on my 3750 ip-base switch. The 3750 has two VLANs, each linking to its own 2950. I just want vlan 1 hosts on one 2950 to route to vlan 2 hosts on the other 2950. It's driving me crazy...
Okay, here's my config on the 3750. As you can see, my vlan SVIs are up and running and I can ping a host on vlan 1. however, when i try to use extended ping to reach that same vlan 1 host from vlan 2's SVI, it times out. my vlans do indeed have the vlan 1 SVI as their default gateways.
Please help!!
Matt
Switch#
Switch#show run
Building configuration...
Current configuration : 1136 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision ws-c3750g-12s
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
description TO VLAN 1 2950 SWITCH
switchport mode trunk
!other interfaces omitted...
interface GigabitEthernet1/0/12
description TO VLAN 2 2950 SWITCH
switchport trunk allowed vlan 1,2
interface Vlan1
ip address 20.40.254.254 255.255.0.0
interface Vlan2
ip address 10.135.254.254 255.255.0.0
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
Switch#show int trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/1 on 802.1q trunking 1
Gi1/0/12 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/1 1
Gi1/0/12 1-2
Port Vlans allowed and active in management domain
Gi1/0/1 1
Gi1/0/12 1-2
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/1 1
Gi1/0/12 1-2
Switch#ping 20.40.1.1
Sending 5, 100-byte ICMP Echos to 20.40.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/6/9 ms
Switch#ping
Protocol [ip]:
Target IP address: 20.40.1.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.135.254.254
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Packet sent with a source address of 10.135.254.254
Success rate is 0 percent (0/5)
Switch#
sundar.palaniappan Wed, 03/21/2007 - 16:00
  • Green, 3000 points or more
Matt,
What's the IP/subnet_mask of the host 20.40.1.1. What's the default gateway set to on this host?
Though this mayn't be causing this problem, configure the ports as access ports as shown below as all the hosts connected to the 2950 switches belong to just one VLAN. Configure the port(s) on the 2950 as an access port as well in their respective VLANs.
switchport mode access
switchport access vlan 1
switchport access vlan 2
The problem appears to be with the host configuration.
Sundar
acomiskey Wed, 03/21/2007 - 17:25
From your first post...
"my vlans do indeed have the vlan 1 SVI as their default gateways."
Both vlans would not have the same gateway. vlan 1 gateway is 20.40.254.254, vlan 2 gateway is 10.135.254.254.
mahmoodmkl Wed, 03/21/2007 - 23:46
  • Gold, 750 points or more
u need to have the SVI's ip address as the gateway address for r u r respective clinets in the respective vlans.
Ensure that ip routing is enabled on u r switch.
From where u r performing the extended ping.
The source interface should be one of the interfaces in u r switch.
Mahmood
matt_heff Thu, 03/22/2007 - 09:30
So, I got an identical 3750, copied the config over, and everything works fine. Hooked up the original 3750, and it still doesn't work.
Very, very strange...
Thanks to all for the help!
Matt
cdakhlia Tue, 04/03/2007 - 05:31
I have tried as you, and the same it does not work. But I tried this:
Validate reply data? [no]:y
and it worked
Chokri
