new router connection problem
had to switch back to main router but here are the configs from all 3 routers:
Branch Office 3640
Branch3640#show int Serial1/0:0
Serial1/0:0 is up, line protocol is up
Hardware is DSCC4 Serial
Description: Line To NY
Internet address is 212.150.232.117/30
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1634638 seconds on reset, Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 18w3d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 16
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/7/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 384 kilobits/sec
5 minute input rate 0 bits/sec, 1 packets/sec
88099334 packets input, 817815933 bytes, 0 no buffer
Received 1307448 broadcasts, 0 runts, 2 giants, 0 throttles
26516 input errors, 2298 CRC, 24198 frame, 0 overrun, 0 ignored, 20 abort
86028637 packets output, 1995405079 bytes, 0 underruns
0 output errors, 0 collisions, 75 interface resets
4 carrier transitions
Timeslot(s) Used:1-8, SCC: 0, Transmitter delay is 0 flags
Branch3640#show run int s1/0:0
Building configuration...
Current configuration : 153 bytes
interface Serial1/0:0
description Line To NY
ip address 212.150.232.117 255.255.255.252
ip nat outside
ip policy route-map deny-dos
end
Branch3640#show ip route
Gateway of last resort is A.B.C.D to network 0.0.0.0
212.150.233.0/28 is subnetted, 1 subnets
S 212.150.233.176 [1/0] via 212.150.232.118
212.150.232.0/30 is subnetted, 2 subnets
S 212.150.232.16 [1/0] via 212.150.232.118
C 212.150.232.116 is directly connected, Serial1/0:0
Main Office 3640
Main3640#show int Serial2/0
Serial2/0 is up, line protocol is up
Hardware is QUICC with integrated T1 CSU/DSU
Description: Branch1
Internet address is 212.150.232.118/30
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 91846
Output queue: 0/1000/64/91840 (size/max total/threshold/drops)
Conversations 0/18/256 (active/max active/max total)
239108891 packets input, 2287448228 bytes, 0 no buffer
Received 5646002 broadcasts, 44 runts, 12354 giants, 0 throttles
2895649 input errors, 1104108 CRC, 1013460 frame, 0 overrun, 0 ignored, 778
077 abort
251349077 packets output, 1815526810 bytes, 0 underruns
0 output errors, 0 collisions, 4852 interface resets
52 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Main3640#show run int Serial2/0
Current configuration : 156 bytes
interface Serial2/0
description Branch1
ip address 212.150.232.118 255.255.255.252
ip nat outside
service-module t1 timeslots 1-8
end
212.150.232.0/30 is subnetted, 1 subnets
C 212.150.232.116 is directly connected, Serial2/0
Main Office 2611 - this is now disconnected, when the line is here it does show up
newMain2611#show int Serial0/0
Serial0/0 is down, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
Last input never, output never, output hang never
Conversations 0/0/256 (active/max active/max total)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
newMain2611#show run int Serial0/0
Current configuration : 163 bytes
interface Serial0/0
description Branch1
ip nat outside
end
