Client association between RAPs & MAPs (Cisco Aironet 1510)
Mar 21st, 2007
How do you fix the association bugs that the 1510s have?
My problem is when a client (like a laptop) associates to the MAP (Mesh Access Point) or RAP (Rooftop Access Point), the client doesn't hand off it's wireless connection to the access point with the better signal strength. Is there a setting or configuration on the Wireless LAN Controller that would help this problem?
ebreniz Wed, 03/28/2007 - 06:35
  • Silver, 250 points or more
There are no issues roaming between RAP. Try upgrading the code of WLC to 4.0.179.8 and also try upgrading the client software since it is the client which should to access point with better signal.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
