Forward No Answer Delay on 7960 incorrect
I set the "Forward No Answer Delay" on my CCM 4.1(3) to 16 seconds and the number of rings, 4, are correct on all of my 7912's and 7940's but the 7960's are ringing only 3 times. So, I tried setting "No Answer Ring Duration" to 16 directly on one of the DN's on the 7960 and it still does the same. On the 7960 itself I tried enabling the "Forwarding Delay" but that did not help either. What am I missing? Thanks for your help.
gogasca Wed, 03/21/2007 - 23:18
  • Green, 3000 points or more
Ok in the DN itself the parameter is "No answer ring duration", make sure you configure it in the Forward settings and NOT under the MLPP...
If all is ok. I would restart CCM.exe (Not recommended never never, but if you want a root cause we may check CCM|SDL and DBL traces)
