router not synchronizing with ntp server
rajesh_colt
My router is not synchronizing with my ntp server , giving here the details,for ntp staus command and ntp assosciation..
scheduler allocate 20000 1000
ntp source FastEthernet0/0
ntp master 2
ntp server 172.17.7.1
#sh ntp status
Clock is synchronized, stratum 2, reference is 127.127.7.1
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**18
reference time is C1E75CDC.B692885E (14:31:16.713 INDIA Sun Feb 2 2003)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 8656633.33 msec, peer dispersion is 8656633.33 msec
#sh ntp associations
address ref clock st when poll reach delay offset disp
*~127.127.7.1 .LOCL. 1 12 64 377 0.0 0.00 0.0
+~172.17.7.1 .LCL. 1 4 64 377 26.3 130362 5.3
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
I dont understand what is that 127.127.7.1 ,
my ntp server configured in router is 172.17.7.1 but i think it is not synchronizing with that, can anybody help me out...in resolving this issue..
thanks in advance...
11 Replies 11
Joe Clarke
127.127.7.1 indicates that this router is an authoritative NTP source, and its clock is synchronized with itself. I'm not sure you want to configure this router as a master. If you just want it to be an NTP client of 172.17.7.1, then remove the ntp master command, and the clock should sync.
If you do want this device to be an authoritative time source, configure yourself with a stratum of 3 or higher:
ntp master 3
hi,
i removed ntp master command...then also it is not getting synchronized with ntp server..giving the details..below ..please help thanks in advance...
~172.17.7.1 0.0.0.0 16 - 64 0 0.0 0.00 16000.
please help....
Check to make sure that there is no firewall or filter between you and your NTP server. NTP operates over UDP port 123. You might also want to enable debug ntp packets to see if the NTP server is replying to your sync requests.
Also try setting the time manually to approximately the correct time. Sometimes if the time on the router and the NTP server are too far apart the device will not sync.
can you give me sample ntp configuration on ntp server and on ntp client...
both ntp server and ntp clients are cisco routers. ntp server router is 3600 series router and it is getting synchronized with another ntp server , it is working also. but the other router 2600 series which is connected through serial interface to 3600 series is not getting synchronized...
For a client, I just typically add:
clock timezone EST -5
clock summer-time EDT recurring
ntp server x.x.x.x
As for the server, you can set the device's local clock to be authoritative using the ntp master command. You can optionally configure NTP broadcasts on various interfaces using the ntp broadcast command.
More info plus some configuration examples are available at http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800ca66f.html#wp1001170 .
In client I configured ntp broadcast client on my serial interface , which is directly connecting to my ntp master..and in ntp
master serial interface ntp broadcast X.X.X.X (client address) , my client gets the ntp broadcast also, but still it is not getting synchronizing
in ntp client router my config is
ntp clock-period 17179871
ntp source Multilink1
in ntp server router(172.26.X.X) config (from where my client router needs to get synchronize)
ntp source FastEthernet0/0 (interface gets connected to 172.17.x.x)
ntp master 2
ntp server 172.17.x.x (this is the parent ntp server from where my ntp server router get synchronization )
I am attaching sh ntp associations, sh ntp associations detail, sh ntp status in my router (client router)
is their any thing mor i need to configure in my client router and parent router.... pls help thanks in advance...
192.168.100.5 172.17.7.1 2 43 64 76 2.2 48034. 875.2
#sh ntp associations detail
192.168.100.5 dynamic, insane, invalid, stratum 2
ref ID 172.17.7.1, time C9ADEBCE.AEB67D4D (11:31:50.682 india Fri Mar 23 2007)
our mode bdcast client, peer mode bdcast, our poll intvl 64, peer poll intvl 64
root delay 42.21 msec, root disp 3292.74, reach 37, sync dist 4190.201
delay 2.24 msec, offset 48034.3069 msec, dispersion 875.24
precision 2**18, version 3
org time C9ADECE0.A3D1E395 (11:36:24.639 india Fri Mar 23 2007)
rcv time C9ADECB0.9AB2A301 (11:35:36.604 india Fri Mar 23 2007)
xmt time C9ADEC85.92DF1C1E (11:34:53.573 india Fri Mar 23 2007)
filtdelay = 2.37 2.24 2.35 2.67 4.38 0.00 0.00 0.00
filtoffset = 48034.5 48034.3 48034.2 48033.9 48035.0 0.00 0.00 0.00
filterror = 0.02 0.03 0.05 0.06 0.08 16000.0 16000.0 16000.0
#sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 249.9999 Hz, precision is 2**24
reference time is C9ADE8CD.92D79FE1 (11:19:01.573 india Fri Mar 23 2007)
root dispersion is 0.02 msec, peer dispersion is 0.02 msec
Since you want to use broadcast NTP, you need to configure the interface on which to send the updates to the client (i.e. using the ntp broadcast command). And on the client, you need to enable reception of broadcast. So, say that the server is connected to the client across interface Multilink1. Do this on the server:
interface Multiink1
ntp broadcast
Then on the client:
I have already configured it in the interface before the above post , it is getting ntp packets ...as you can see in the details sh ntp associations, sh ntp associations detail, sh ntp status..for your refernce i am attachin it agian...
#sh ntp status
in sh ntp status 192.168.100.5 is my ntp broadcast multilink interface and 172.17.7.1 is where ntp broadcast router synchronize with...and theese are all taken from ntp broadcast client router..so it clearly says that it recives the packet but not synchronizing....
great thanks for your help and support...and hope to continue
It would be helpful to see the whole picture including a show ver and show run from both routers. The output of show ntp status and show ntp associations from the server router would also help.
