3750 disaster recovery
Answered Question
Mar 21st, 2007
My 3750 switch is not booting and is stuck at the prompt switch:
i tried to initialize the flash and load the IOS via the boot command but it gives an error.
Is there any xmodem procedure which i can do to load another software
Correct Answer by Amit Singh about 9 years 6 months ago
Yes, you can use Xmodem to recover the switch. Please use the link below for recovering 3750 from softwaqre failures:
HTH,Please rate if it does.
-amit singh
Overall Rating: 4 (1 ratings)
mtechnology Wed, 03/21/2007 - 23:11
thanks for the link..
Is there anyway to increase the baud rate cos it is taking a long time to load the file with the normal rate
podhillo Mon, 06/07/2010 - 08:01
Please try the following steps to disaster recovery.
Do check the connections before proceeding:
dir flash:
set baud 115200 ---> for faster trasfer of image, do open a new hyper terminal with baud rate set to 115200.
copy xmodem:flash:
More details provided in the following link:
Hope it helps!
