vpn isakmp strange
Mar 21st, 2007
hi guys need ur help in this, i developed a simple site to site vpn between 2 routers on a serial link in my lab, i connected 1 pc to routerA eth 0 and other pc to routerB eth 0. now i ping from both ends and the tunnel established successfully ( i verified using sh cry isakmp sa, sh cry ipsec sa ) now i cleared isakmp by clear crypto isakmp on routerA and it got deleted check this
RA#sh crypto isakmp sa
dst src state conn-id slot status
11.0.0.1 11.0.0.2 MM_NO_STATE 1 0 ACTIVE (deleted)
now i thought that the tunnel is torn down, i again issued ping from 1 pc it got successful, so i checked again by sh cry isakmp sa but it was empty !!! i checked sh cry ipsec sa and it was still encaps the packets mean phase 2 tunnel was still up !! how is this possible after i terminated iskamp how is it possbile that phase2 tunnel is still up ??? plz tell me
thanks in advance
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 03/22/2007 - 01:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
IF you want to tear the tunnel down completely you need
1) clear crypto isakmp sa
2) clear crypto ipsec sa
Tearing down the phase 1 connection will not necessarily tear down phase 2
Jon
shaila_rox Fri, 03/23/2007 - 23:09
thanks for the reply jon, can u also plz refer to a cisco doc which defines this problem ?
thanks again in advance
