Use SSH to retrieve data
Mar 22nd, 2007
I have scheduled a netshow jobs to run daily, however i want the lms server to use SSH when running this "show jobs", how do I specify in LMS to use SSH whenever it connects to routers?
Craig Balfour Thu, 03/22/2007 - 01:00
Go to RME > Administration > Config Management and set the Application Name field to NetShow. You can now select your protocols (Telnet and / or SSH) and the protocol order. You want the protocol order to be SSH, Telnet.
You will need to setup the router to support SSH logins if you haven't already done so:
ip domain-name
crypto key generate rsa
ip ssh version 2
line vty 0 15
transport input telnet ssh
