4500
Answered Question
Mar 22nd, 2007
Dear All,
I am having 4507R chassis in whcih two SUPs are installed .
in case of failure of Redundant SUP,I want to copy the image which is running on Active SUP to my redundant SUP ( at time when new Redundant SUP is installed )
can i get document on same ?
regds,
aman
Correct Answer by Jon Marshall about 10 years 4 months ago
From the 4500 configuration guide
"Copying Files to the Standby Supervisor Engine
If you want to manually copy a file from the active supervisor engine to the slot0: device on the standby supervisor engine, use this command:
Switch# copy source_device:source_filename slaveslot0:target_filename
To copy a file to the bootflash: device on a standby supervisor engine, use this command:
Switch# copy source_device:source_filename slavebootflash:target_filename"
Attached is the full link to the 4500 redundancy documentation
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a0080233f9e.html
Jon
Overall Rating: 4.5 (2 ratings)
Correct Answer
Jon Marshall Thu, 03/22/2007 - 02:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
