SNMS pre requisits
Mar 22nd, 2007
Hello, did someone know this error "Server Runtime erro:java.lang.nullpointerException.
I have installed SNMS 1.5 on a Win2003 US SP1 R2.
first the interface didn't want to start because of Java disabled, so I have installed it , and it was working, but know I have the error above concerning Server Runtime error, and I can't get the configuration file of all my switch.
I have experience with LMS, and I used to change the backup directory for my configurations files.
What is the problem?
Do I have to reinstall all the OS end the application.
frankzehrer Thu, 03/22/2007 - 05:26
Hi Zaydi,
do you have 1.5 or 1.5.1 installed?
What Java version is installed?
Is the Windows OS installed with english locales settings??
Best regards,
Frank
karima-zaydi Thu, 03/22/2007 - 05:33
I have Windows 2003 US SP1 R2 installed, I've installed SNMS 1.5, and I upgrade it on SNMS 1.5.1 to be compatible with the SP1.
I have installed the java Jre5, but I have desintalled it, and with netconfig the server give me the java j2re4_ ....
I have seen that the problem could be the R2 ???
do I have to reinstall it ?
frankzehrer Thu, 03/22/2007 - 06:07
thats right. The R2 is not supported. You should install a W2K3 and not the R2 Version.
Best regards,
Frank
karima-zaydi Thu, 03/22/2007 - 06:09
So I have to insatll W2K3 without the SP1, then SNMS 1.5, and then the SNMS 1.5.1,and the SP1 of Windows ?
thanks
frankzehrer Thu, 03/22/2007 - 06:41
the clou here is not to use the R2 Version of WIndows 2003.
Best regards,
Frank
