Fax Blocked Voice Port (FXS)
Answered Question
Mar 22nd, 2007
hi,
an outgoing fax call blocked my voice port. it stays in a busy state for days... shut and no shut doesn't put the voice port in a dorm state again, only a reload will correct it... is there any solution instead reloading the c2800?
many thanks
Correct Answer by rhugo about 9 years 8 months ago
Dino -
If you are running IOS 12.4, This seems to be attributed, possibly, to a known bug with the FXS port:
Cisco bug ID CSCse83674
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCse83674
Overall Rating: 5 (1 ratings)
Aaron Harrison Fri, 03/23/2007 - 05:37
Seems odd - if you physically disconnect the cable does the port clear?
If so, use a new cable with only the necessary 2 pins cabled up.
Aaron
Please rate helpful posts...
dinorubio Fri, 03/23/2007 - 11:08
we do not have access to the equipment. we must solve remotely. but it is properly cabled...
i will check the ios version..
thanks
