gmarogi Thu, 03/29/2007 - 06:39
X.25 is a supported option in the PLUS feature packs on the 800 series router. A separate TCP connection MUST be used for each X.25 virtual circuit.In order for a separate TCP connection to be used for each X.25 VC, a unique port must be used for each PVC.
