Intro exam - Question
Mar 22nd, 2007
m new to Networking, studying for the intro exam and have a quick question im hoping someone can help me with.
When Calculating the number of subnets do you sbtract 2?
e.g Using 6 subnet bits are 62 or 64 subnets created?
Brandon Buffin Thu, 03/22/2007 - 13:00
It depends. The purpose of subtracting 2 is to exclude the all 0s and all 1s subnets. Prior to IOS 12.0 you could not use these subnets by defualt. You could however, use the command "ip subnet-zero" to allow their use. As of IOS 12.0, "ip subnet-zero" is enabled by default. So, if you're using "ip subnet-zero" you would not subtract 2. If you are not using "ip subnet-zero", you would subtract 2. Take a look at the following link.
Hope this helps. If so, please rate the post.
