Splitting a PRI into multiple BRIs
Mar 22nd, 2007
hi,
I know i can split a PRI in a various ways, what i would like to know is how can i split the PRI and then push the groups to specific BRI ports.
e.g. i have a PRI with 20 lines, i would like to separate it into 4 BRIs and the rest, could i add two vic-bri cards and send those PRI groups/channels to the physical BRI ports so that a customer could plug their stuff in to the ports and then use the rest as normal
I imagine it is something like ds0-groups or trunk-groups but then how can i assign it to a bri, would i use something like a voice-port command etc.?
cheers
paul
