03-22-2007 09:00 AM - edited 03-03-2019 04:15 PM
HI
IOS 12.4 Advanced Enterprise Services willWorking on the 2620xm;if so how much the flash & Dram should be?
regards
ali
Solved! Go to Solution.
03-22-2007 09:34 AM
ali
The size of the image is the same no matter whether it is in a lab or in production so the requirements for flash should be the same.
You probably do not need quite as much memory to run in a lab as to run in production. But I do not think that it changes the requirement for memory very much.
If your router has less flash or less memory than the requirements stated you could always try to load the image and see what happens. But if it were me I would be reluctant to try to load and run an image on a router that had less than the required resources.
Rick
03-22-2007 09:04 AM
ali
According to the Software Advisor on CCO 12.4 Advanced Enterprise Services should have 128 of memory and 32 of flash.
Rick
03-22-2007 09:22 AM
HI RICK!
We need this routers/ios 12.4 for lab not for production;now waht is ur opinion rick
10xs
03-22-2007 09:34 AM
ali
Rick
03-22-2007 09:37 AM
Hi Rick!
Thanks a lot for ur valuable info
10xs
