Configuring help for a CSS (11500)
Mar 22nd, 2007
I have an application which makes an IP Socket connection between Point A and Point B. What I want to do is put the 11500 between these two points and configure it as follows: If the port is available, route using a persistent connection to Point B. However, if the persistent connection fails, try to reestablish it otherwise move the connection to Point C. I have 800 of these connections which I want to implement.
Can you give me an example of how I can do this?
Point A is
Point B is port 51
Point C is port 51
