Fiber connection from a Cat 6509 to a Foundry Server Iron
Mar 22nd, 2007
Hey There...
I'm in the process of removing all of my old Foundry equipment and replacing it with Cisco. I just tried to connect my Foundry Server Iron to my Cisco 6509E via MM Fiber (I do have an sx fiber card). On the Foundry side it shows up but on the cisco side it shows "notconnected". Does anyone know why cisco side won't come up. I've made sure they were in the sam vlan (although for just a link light I don't think that matters). I've also change the port (cisco side) to a route port but I still don't get a link light.
Mike C.
ankbhasi Thu, 03/22/2007 - 11:49
Hi Mike,
Can you paste which sx card are you having? What is the model of line card on which you are connecting your Foundr switch?
Can you check with "sh mod" on cat6k if all the line cards are showing you as OK status?
Ankur
MICHAEL CICCONE Thu, 03/22/2007 - 12:01
Hey Ankur,
Here is the info from the Foundry side:
Hardware is GigabitEthernet, address is 00e0.5204.c2a8 (bia 00e0.5204.c2a8)
Configured speed 1Gbit, actual 1Gbit, configured duplex fdx, actual fdx
Member of L2 VLAN ID 1, port is untagged, port state is FORWARDING
STP configured to OFF, priority is normal, flow control enabled
mirror disabled, monitor disabled
Not member of any active trunks
Not member of any configured trunks
No port name
Here is the Cisco Info:
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL10382B0L
Mod MAC addresses Hw Fw Sw Status
1 0018.ba04.bb70 to 0018.ba04.bb87 2.5 12.2(14r)S5 12.2(18)SXF7 Ok
The GB is the "SX" model. I'm not sure what it is on the Foundry side.
Mike
MICHAEL CICCONE Thu, 03/22/2007 - 13:29
Did try that and it doesn't seem to make a diffence. I checked on the Foundry side to see if I could modify the speed or duplex. But you cannot.
MICHAEL CICCONE Thu, 03/22/2007 - 13:50
Sure
Show interface for Cisco:
show inter gi1/8
GigabitEthernet1/8 is down, line protocol is down (notconnect)
Hardware is C6k 1000Mb 802.3, address is 001a.30f9.9000 (bia 001a.30f9.9000)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is SX
input flow-control is off, output flow-control is desired
Clock mode is auto
Last input never, output never, output hang never
Last clearing of "show interface" counters 3d01h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
show interface of Foundry:
show inter e 9
GigabitEthernet9 is up
No port name
5 minute input rate: 0 bits/sec, 0 packets/sec, 0.00% utilization
5 minute output rate: 4544 bits/sec, 6 packets/sec, 0.00% utilization
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 ignored
0 multicast
12862 packets output, 965002 bytes, 0 underruns
MICHAEL CICCONE Thu, 03/22/2007 - 14:58
Foundry:
No port name
5 minute output rate: 0 bits/sec, 0 packets/sec, 0.00% utilization
0 multicast
26366 packets output, 1787064 bytes, 0 underruns
cisco:
Clock mode is auto
Last clearing of "show interface" counters 3d02h
nyr.hakeem-habeeb Thu, 03/22/2007 - 15:29
the only differnce i can see on both side is the fndry. has its port settings fixed (i.e. flow control, duplex hence autoneg is off) i can on suggest to match those interface settings on the cisco end. the key things here are flow-control and duplex. so we could set flw-ctrl on the cisco to on.
int g1/8
flowcontrol receive on
flowcontrol send on
Fingers crossed!!!
