Webpage timeouts when behind the ASA-5510
Mar 22nd, 2007
Has anyone experienced this problem?
If I'm sitting behind an ASA 5510 and surf the net at a few of the websites i get a timeout/webpage not found error! i have setup a pix501 on the same public segment as the ASA and when access the same pages from behind it they come up fine! I have changed some of the timeout settings but nothing seems to change it.
any ideas?
abinjola Thu, 03/22/2007 - 13:09
  • Cisco Employee,
disable the inspect http
also increase the length of the DNS maximum length on your ASA..
suschoud Fri, 03/23/2007 - 07:53
  • Gold, 750 points or more
could you post the syslogs generated at the time of connection attempt.what's the tcp flag for the connection which times out.
do u have url server configured in conjunction with asa.
if that's the case you could try increasing the url length for the url server.
hth
sushil
cisco tac
