Reset a Single Unity Port (take 2)
Mar 22nd, 2007
With Unity 4.0.5 is there a way to reset a single unity port that becomes "not registered" with Callmanager.
Ginger Dillon Fri, 03/23/2007 - 13:31
Hi -
Using Status Monitor from the Unity server, you can display the ports. Select the port and then click the button "Reset Port" at the bottom of the screen. To be honest, from my recall working with 4.0(5), this was not always successful. In those instances, I tried resetting Unity from the Systray first or second - rebooted the server. Ginger
jbarcena Sun, 03/25/2007 - 15:35
You can reset it using the CCMAdmin webpage, go to that port and select reset.
