VPN routing to addess on same subnet
Mar 22nd, 2007
I have a class C subnet delivered by my ASA 5540 for Remote VPN (10.3.18.0). When someone VPNs in they get an address like 10.3.18.6. They can get to other networks that are not on 10.3.0.0, like 10.10.0.0 or 10.19.0.0, but are not able to get any network 10.3.0.0. (config attached) This used to work and I'm not sure what I have done to stop it. Can someone help? Thanks.
Overall Rating: 5 (1 ratings)
acomiskey Thu, 03/22/2007 - 12:42
  • Green, 3000 points or more
You should use a completely different subnet for vpn pool. This statement is not true...
route inside 10.0.0.0 255.0.0.0 10.32.254.254 1
mhidde Thu, 03/22/2007 - 13:57
Thank you. You may find this odd, but I swear this used to work. :) Anyway, I broke out the routes for the specific subnets and then was able to reach the site on 10.3.0.0. Thanks for your help.
acomiskey Thu, 03/22/2007 - 14:47
Stranger things have happened, glad I could help.
