Slots and Ports on 4400 controller
Mar 22nd, 2007
What are the slots and ports on a 4400 controller? Why when the LAG is enabled, you cannot create interfaces with a primary port other than 29? What does the "primary port" mean?
AP Name Slots AP Model Ethernet MAC Location Port
ap1 2 AP1010 00:0b:85: default_location 1
ap2 2 AP1010 00:0b:85: default_location 1
ap3 2 AP1010 00:0b:85: default_location 1
ap4 2 AP1010 00:0b:85: default_location 1
ap5 2 AP1010 00:0b:85: default_location 1
ap6 2 AP1010 00:0b:85: default_location 1
ap7 2 AP1010 00:0b:85: default_location 1
Justin
beth-martin Wed, 03/28/2007 - 12:05
Modules contains ports. Modules are inserted into slots just like PCI slots.Yes the LAG primary port is always port 29 .Primary ports are nothing but normal ethernet port on WLC which plugs into the switch.
Steven van Jaarsveld Thu, 04/12/2007 - 11:15
Hi There
Here is a description of the ports on the 4404 WLC licensed for 100 AP support:
--"AIR-WLC4404-100-K9?This 4404-100 controller uses four GigE connections to bypass one or two single network failures, and communicates with up to 100 access points. It has two back-panel slots for future expansion modules."--
When connecting more than 50 AP's, you have to configure additional AP Manager interfaces on the configuration page and in order to connect all 4 SFP interfaces you will need 3 additional AP Manager interfaces i.e - 4 AP Manager interfaces = 1 per physical port.
Hope this Helps.
Let me know if you need more help
Cheers
Steven
yytellmey Thu, 04/12/2007 - 14:48
Thanks Steven.
What does "slots=2" mean? What is the "slots"?
Justin
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
