SNMS Problem
Mar 23rd, 2007
Hello all,
I have problems with Syslog which are not received in WUG, I think this is because RME get them with 162 port, Wht Can i do to receive them on WUG??
Then, Ciscoview doesn't give me the card SupII+TS et X4124 of my 4503, and I 've got pb with the 2960?
And the last pb, is that I can't run a compare Config, or Config Editor and Netconfig ...
irisrios Thu, 03/29/2007 - 06:51
  • Silver, 250 points or more
It's recommended that you have read onlyand read write community strings on your equipment if you want Cisco Works to discover your network.Also, you must enable DNS and CDP on all of the devices you wantto be discovered
