Boot from LAN using Wireless Adapter
Mar 23rd, 2007
I have one Cisco Wireless PCI Adapter. Does it have a feature like PXE BootROM in NIC, so I can boot from LAN using wireless adapter?
scottmac Fri, 03/23/2007 - 20:32
I'm pretty sure it doesn't. At issue would be the necessary setup for things like SSID.
Maybe in the future; many motherboards & chipsets are including Wireless NICs, they would need to provide some setup in the BIOS to configure the basic communication parameters necessary to establish the Layer one / Layer two link.
Good Luck
csannedhi Sun, 03/25/2007 - 07:30
Your machine can boot using the Wireless PCI adapter as long it is already configured for your wireless network. Give it a try.
ciscohelpdesk Tue, 03/27/2007 - 21:43
Hi csannedhi,
Could you give me more details about that? I know some laptops can do. But ScottMac said that desktops could not.
