Delay when calling outside calls
Answered Question
Mar 23rd, 2007
I m installing a Call manager express + IP phones.When i dial numbers other than extensions (9.* , outside LAN calls, to my mobile for example), the call needs more than 30 seconds to be proceeded correctly and so the end party rings.
Please advice..
Correct Answer by lpezj about 10 years 2 months ago
With the pattern 9.*, CME will wait for any number of digits to be dialed. Until the interdigits timeout doesn?t expire, CME is not going to dial the full number.
Try to define patterns that it accomodate a fixed number of digits, for example, 9.XXXXXXXXX (CME will wait for nine digits and it will dial the number). But take care of not overlapping patterns because you will remain in the same problem, for example, 9.XXXXX and 9.XXXXXX.
Hope this helps,
Juan Luis
Overall Rating: 5 (1 ratings)
Correct Answer
lpezj Fri, 03/23/2007 - 02:44
  • Gold, 750 points or more
Hope this helps,
Juan Luis
