Interface problem
Arvind kumar
on my switch I am getting this log message:
Logging history:
2007-03-17 12:21:07 @5-LINKUPDOWN:Gi0/10 changed state to down
2007-03-17 12:21:07 @5-LINKUPDOWN:Gi0/11 changed state to down
2007-03-17 12:21:10 @5-LINKUPDOWN:Gi0/10 changed state to up
2007-03-17 12:21:10 @5-LINKUPDOWN:Gi0/11 changed state to up
The interface goes DOWN & UP for a small fraction of time. My servers are connected to this port.Hence the application hangs & afterwords need to restart the services. pls help to identify the problem for this.
Duplex settings - FULL
Speed - Auto
Hi Arvind,
What is the OS of the servers connected, Duplex and Speed setting.
Suggest to set
Duplex full
Speed 100
Monitor the sh int on router / Switch and try tweeking the above both ends... You will succeed if there is no hardware problem.
You can also try changing the ports if you have free ones.
S. Shantharam
