Create users/profil easily
Answered Question
Mar 23rd, 2007
Creating users and/or profiles in a CCM is not a quick operation.. Is there a manner to make these operations faster? (ex : in order to created many users/profiles at the same time)
If yes, is it available from all versions of CCM ?
Correct Answer by Aaron Harrison about 10 years 2 months ago
Yes - you can use BAT:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00800da3d8.html
There are versions of this for all recent versions of CallManager. Basically you create spreadsheets and import the users/phones/whatever else you wish to add.
It's quite quick once you are accustomed to it.
You are also able to add users via LDAP but that's much more involved and less supportable/prone to errors.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 03/23/2007 - 05:34
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
