Attendant Console in Multitenant Environment
Mar 23rd, 2007
Hopefully a quick question. A customer trades under multiple company names. They wish to have all four of the main DIDs coming to one Receptionist, using Attendant Console. Apparently, they have been told from someone at Cisco that it is possible to have AC show them which company is being called, i.e. which DID was originally called (obviously the translated to a DN), so as to allow the receptionist to answer the phone with an appropriate greeting for each firm.
I know that ARC Console does this very nicely, but the last time I looked at Attendant Console all it showed on each line was the calling number, not the called number!
Can anyone shed any light on this?
Many thanks
Marc
Aaron Harrison Fri, 03/23/2007 - 06:06
Hi Marc
It will show just calling number I think if you use normal queueing or just hunting...
If you use broadcast hunting you see the pilot point, calling number, and waiting duration.
So you could have muliple pilot points/hunt groups, but with the same users in the groups. This would mean users have to pull calls out of the broadcast group, but would give you the ability to see where callers have come into the system.
Aaron
Please rate helpful posts...
marcbutler Fri, 03/23/2007 - 06:52
Hi Aaron
Many thanks for your reply. Can I make sure I have this correct in my mind? With broadcast hunting, and with multiple pilot points and associated hunt groups enabled, and the operator/s user ID being a member of all of such, then when a call comes in to any of these pilot points, they will display the calling number and the pilot point from which the call came to and was passed from to the Attendant Console? Without broadcast hunting, it would not be possible to see the origination point of the inbound call?
Am I correct on the above.
Many thanks for your clarification in advance. I will rate the post after this, I promise!
Rgds
Marc
Aaron Harrison Mon, 03/26/2007 - 05:09
Hi Marc
Yes - that's correct.
If you aren't using broadcast you just see the calling number and your number.
With broadcast the broadcast windows in AC shows the pilot number and calling number, and it can show waiting time...
Make sure your clients' PCs have some form of speaker though; usually they want an audible altert when a call is available as the phone won't ring (you have to manually pick a call to answer).
Aaron
chadlincoln Mon, 09/01/2008 - 17:22
I had this same dilema. Let's say calls come in on 2000. I created a CTI RP with extension number 2000 on it. I CFA to the AC pilot point. The call shows up on the AC as being forwarded by 2000.
stafford.slater Wed, 09/03/2008 - 00:05
The easiest way we have found to set this up is to assigne each company a seperate number/line and enter that number in the attendant console users speed dial list with the company name. when a call comes in it will show up with the companies name.
