Problem in Load Balanceing........!
Mar 23rd, 2007
We are using SDM link between to router.
COnfig on router 1
ip cef
inte gig0/1
ip ADDRESS 1.1.1.1 25.0.0.0
ip load shareing per-packet
no ip proxy-arp
no ip mroute-cache
no autonegotiation
load-interval 30
dulpex full
speed 100
media type RJ45
inte gig0/0
ip ADDRESS 2.2.2.1 25.0.0.0
no ip proxy-arp
no ip mroute-cache
no autonegotiation
load-interval 30
dulpex full
speed 100
media type RJ45
ip route 172.16.2.0 255.255.255.0 1.1.1.2
ip route 172.16.2.0 255.255.255.0 2.2.2.2
COnfig on router2
ip cef
inte gig0/1
ip ADDRESS 1.1.1.2 25.0.0.0
no ip proxy-arp
no ip mroute-cache
no autonegotiation
load-interval 30
dulpex full
speed 100
media type RJ45
inte gig0/0
ip ADDRESS 2.2.2.2 25.0.0.0
no ip proxy-arp
no ip mroute-cache
no autonegotiation
load-interval 30
dulpex full
speed 100
media type RJ45
ip route 172.16.1.0 255.255.255.0 1.1.1.1
ip route 172.16.1.0 255.255.255.0 2.2.2.1
Now with this config...
When i m sending 100 packet from HOST A to HOST B then as per me 50 should go on one link and another 50 should go on another link.
BUT here only 20 packet will go on one link and another 20 are going on another link........Due to this to go 100 packet from HOST A to HOST B i m getting
latencey............i.e. i m geting low thoughput.
If i remove one link then i m geting 100% thoughput on the remained link.
PLease let me know where is root cause of problem ?If u are haveing any alternate solutions for same (to load balance )let me know.
==========SEE ATTACHMENT FOR TOPLOGY=========
spremkumar Mon, 03/26/2007 - 01:48
  • Red, 2250 points or more
Hi Ganpat
Make use of /30 subnet on your interfaces instead of using the current one.
Also in the config posted the mask is not mentioned properly if its the exact config taken out from your router then make sure you try reconfiguring with the above said /30 subnets.
once you are done with changing the mask check for packet loss.
Once you are done with the necessary testing and still getting loss then redefine ip route statement defining the outgoing interface followed by the next hop ip..
regds
