Cat6506 sess 15 username forgotten...help!
Mar 23rd, 2007
so i configured a 6506 switch and am all set with that.
then, i proceeded to configure sess 15, the msfc2 layer 3 routing.
I put a local console password and a vty line password and now everytime I try to console into the sess 15, it's asking for a username.
I tried the blank username and the cisco and it wouldn't take it.
so now, i can console into the switch but not the router.
please help!!!
what could the username be? I have not set any username.
i'm under the gun so any help would be appreciated.
Amit Singh Fri, 03/23/2007 - 09:15
  • Cisco Employee,
By default the MSFC doesnot have any password.If you are not able to login to it that means you have lost the password and need to a password recovery. Please follow the steps below:
1. Reboot the switch.
2. During booting sequence, the Supervisor engine boots for first 30 seconds and then gives the ownership to MSFC i.r Router. When you get the message " changing ownership to route processor", please try to break into MSFC rommon using " CTRL+BREAK".
Please make sure that you press "CTRL+BREAK" the moment you see the messgage " CHANGING OWNERSHIP TO ROUTE PROCESSOR" otherwise you have to reboot the switch again.
3. You will fall on the MSFC rommon prompt (rommon:).Verify the same using " dir flash:" and it should show you the MSFC image there.
4. Change the configuration register using command " confreg ox2142 ".
5. Reset the router and the MSFC will boot without the NVRAM config.
6. You will be able to " session 15 " and access the router.
7. Once you are on the router do the following:
Config t
no aaa (if you have enabled AAA)
no enable secret
no enable password
line vty 0 4
no login
no password
router(config)# config-resgister 0x2102
router(config)# exit
router# wr mem
8. Reload the router and the router will boot with its config without the username and password.
Please use the doc below for more refrence:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_password_recovery09186a0080135657.shtml
HTH,Please rate if it does.
-amit singh
