Redundancy
Mar 23rd, 2007
Hi Experts,
We have 2 ISP's consider SP-A and SP-B. Both are connected to Router. We have default routes on Router to SP-A and SP-B. Router is connected to PIX. Patting has been performed for both the ISP's. Now I need some redundancy on PIX so that SP-A fails SP-B takes over or vice versa. I cant use two PIX. Please let me know the solution.
Cheers,
Nik
Overall Rating: 4 (1 ratings)
paolo bevilacqua Sat, 03/24/2007 - 05:30
  • Hall of Fame,
    Founding Member
One solution is configure SLA probes on the router so that when a tracked object becomes unreachable, a floating static route is activated.
The problem is that you will not be able to use SP-A addresses on SP-B link, and viceversa, that means in practice turn, the router must do the NAT, not the PIX.
It's also tricky because it involves multiple subnets, policy routing etc.
Good luck.
