Procedure to Power Off the ISDM-2 Module
Mar 23rd, 2007
Hi Everyone,
I need to inform the operator the procedure he needs to make to power off the ISDM-2 Module. I want to avoid give him access to an administrator account, but I can?t see another way.
Any tip to automatizate this procedure and not requer a lot of commands by the operator ?
Thanks in Advanced
Andre Lomonaco
Overall Rating: 5 (1 ratings)
vitripat Fri, 03/23/2007 - 11:06
  • Gold, 750 points or more
You need to use following command to poweroff the IDSM-2 module from the module-
reset [powerdown]
The reset command without any options will cause the IDSM-2 to perform an orderly reboot. If you add the powerdown option, the IDSM-2 will perform an orderly shutdown and will either power off the device or place it in a state where it can be powered off.
Vibhor.
