Conditional Route Advertisement - VRF Address Family?
Mar 23rd, 2007
I would like to do conditional route advertisement within an IPv4 vrf address family but the "neighbor x advertise-map" command is not available within the vrf address family (at least in the code version I have). It is available in non-vrf address families.
Command/Config reference guides do not show any limitations regarding the command. Before I upgrade code (which may not be possible with my current platform) I wanted to see if anyone is doing this or if there is another way to accomplish the same task.
-Ed-
mheusinger Sat, 03/24/2007 - 00:50
  • Green, 3000 points or more
are you talking about PE->CE or PE->PE/RR ?
