03-23-2007 01:58 PM - edited 03-05-2019 03:04 PM
ERSPAN, what platforms is it supported on? I have found only the Supervisor 720, is it supported by L3 images on the 3750 or 4500's?
Thanks!
Aaron
03-23-2007 04:11 PM
its a high end feature. I check using feature navigator.
Encapsulated remote span, is really just for 7600/6500's with sup 720 and sup 32's.
What are you trying to do... there are other ways to get full span effects over long distances/not vlan media.
-Joe
03-23-2007 04:17 PM
Trying to Span Voice calls over the WAN for recording purposes.
Thanks for any help and assitance/recommendations for this situation.
12-16-2007 12:05 PM
hi Aaron
i know it has been long time for this case, but i would like to know if you have any idea on your situation you might want to share, as i have the same problem now and looking to span voice vlans over L3 links on the 3750 switches ?
appreciate your help..
thanks
