Unity - via AD/Exchange 2nd NIC
Mar 23rd, 2007
AD and Exchange server located in data VLAN and has two NICs each. the default gateway pointing via data VLAN
Can I locate the Unity server to voice VLAN and integrate to AD/Exchange via those server's 2nd NIC which physically connected to voice VLAN?
Thanks in advance,
Tommer Catlin Mon, 03/26/2007 - 10:21
  • Green, 3000 points or more
You are probably complicating things here with your 2nd nic. I dont Windows will understand what you are trying to do with the different networks, then you have to use the routing tool in windows and it gets ugly.
Leave your VLAN's, routing, etc up to the switches. Let them handle the traffic, tagging and where it should go. Trying to do it off the physical NIC is not that great VOIP. You can end up with one way audio. (audio being sent, but not recieved because of the "gateway" nics you have setup)
make senses?
